Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
432 Fragen Alle anzeigen
How to quit the installer
I have got notification for soft wear update and I have allowed to update. After that my iMac is not opening. Message is showing as follows "macOS could not be installed on your computer. Quit the installer to restart your computer and try again." Now how can I quite the installers?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
what OS X are you running? Which update does the APP store say it is?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You should have the possibility to close it from the menu bar but since something went probably bad during install it might be the menubar is not there ? If so you don't have any other alternative left than force shutdown with power button. Hopefully it will boot correctly otherwise you'll have to reinstall the OS.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
How can I get OS, it poss lie to download from Apple Store?
von
Antwort hinzufügen
shamaun1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 142
