Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,3 GHz i5 oder 2,7 GHz i7 Prozessor
782 Fragen Alle anzeigen
MacBook Pro is not BOOTING using ALT and/or to Recovery Mode
I have a MBP 2011 from a customer and I am trying to reinstall the system however trying to use ALT to select the PEN DRIVE with macOS installation is not working. The CMD + R is not working too.
I already tried reseting the SMC and it didn´t help at all. However I tried resetting PRAM and it doesnt work out.
What can I do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You mean Option Key don’t you?
Reference: Mac startup key combinations
Command + ‘‘R’’ may not work if the drive is not prepped (new drive). The newer firmware will automatically jump to internet recovery when you press Command + ‘‘R’’ so you will need a network connection to the internet via Ethernet or WiFi.
Did you replace the HD SATA cable yet? This is a common issue in this series.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Yes I mean ALT/OPTION.
I installed new drive tons of times and NEVER "prepped" the new drive. What should I do if OPTION and CMD+R both are not working?
I didn´t replaced the HD SATA. However I think this is not the case. Cause it came with a QUESTION MARK problem. and I just plugged the new HDD and it instantly showed the Apple Logo, however didnt go through the installation as I said earlier.
Att.
von
Does it boot up with an external drive when you've disconnected the internal?
von
Antwort hinzufügen
Angelo Recaman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 259
