Zum Hauptinhalt wechseln
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
How to remotley disable FRP lock?
I have recently flashed a custom recovery on this phone. Since I forgot to disable frp lock (Re-enabled it by setting up phone after flash) it will be blocked from entering the recovery mode. for some reason it will boot-loop non stop. It will try to load the recovery then crash reboot and repeat. Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You need to put the phone back into download mode via holding volume down + power + home constantly and reflash the firmware or stock recovery file onto the phone.
How to flash firmware if you need it, flash with home_csc and not the non-home csc to avoid factory resetting the phone if needed:
http://updato.com/how-to/how-to-install-...
When you get phone working again go to settings, about phone, software info tap build number 7 times then go developer option and enable OEM unlock.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Ethan Leroux wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 4,948
