Zum Hauptinhalt wechseln
The Dell Inspiron 15-5559 is approximately 15 inches in width and 9 inches in height. This device has a 15.6 inch screen and an Intel 7 Core Processor. The Dell Inspiron 15-5559 comes in a variety of colors that include blue, silver, dark grey, white, and black.
9 Fragen Alle anzeigen
Operating System loader has no signature. Incompatible with secure boo
Operating system loader has no signature. Incompatible with secure boot. All Bootable device failed secure boot verification.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Tried installing your laptop?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Try pressing F2 on bootup and then go into set and turn SecureBook off. That should let it boot up fully.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
No Bootable device found.
von
Can you verify that the HD is good?
von
No bootable devices found.... how to fix it?
von
1. How is disabling SecureBoot a "solution"? and 2. It didn't work anyway. Confirmed that there's no issue with the hard drive. Does anyone have any other suggestions?
von
Hilfreichste Antwort
My colleagues Laptop Dell Inspiron 15-3567 (System Bios: 2.9.0, ePSA: Build 4304.14 UEFI ROM) with OS Windows 10, boot failed with error "Operating System Loader Signature Loader failed signature verification. WARNING: The file may have been tempered with! All bootable devices failed Secure Boot verification." (Note that I am writing this down so that this post shows up in Google Search). The steps listed below worked for me:
1. On Startup, press F12, and on the options, Select BIOS Setup.
2. Reset Bios to default settings (in my case I did Factory Reset).
3. Restart Laptop, go to BIOS setup again.
4. Firstly, Disable Secure Boot Option.
5. Then, Select Boot Sequence menu.
6. Manually ADD additional line with the name "Windows Boot Manager".
7. Select file /EFI/BOOT/BOOTX64.EFI for the entry created in step 7.
8. Exit and Restart. If the Laptop does not boot then uncheck default UEFI boot option in Boot Sequence menu from BIOS, so that the Laptop boots from the boot entry created above.
Bewertung 3
4 Kommentare:
I had the exact same problem with my Dell computer and tried several suggested solutions but none worked until I found yours. And it worked, fantastic!
Thank you so much!
von
Step 6 Manually Add Windows boot manager... going in Add button doesn't show WIN boot manager.
How to add...
von
I followed Raj's solution but now when booting I get the error “No bootable devices found.”
Any ideas?
von
Your mistake caused me to lose the win option I was using? You don't deserve to be a guide, please don't post anything else. One day it will harm your family members
von
bro i also had the same problem but i tried it by my own method
when you turn on press F12 as the moment you see dell symbol
Then i dont rember the exact but select last option below bios setup
then after reaching there ther will be futhur two option you try both one at a time while doing this you will see dell  warning to change that setting but you do that .It worked for i too search the  whole internet but didnt found the solution anywhere  but this my method worked  for me hope it  will work for you
Bewertung 0
Antwort hinzufügen
Raman. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 81
Letzte 30 Tage: 389
Insgesamt: 26,208
