Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
Why did I lose the ringer mute and volume + and - button functionality
I just bought a new battery and the tools to replace it from ifixit and that went ok but I lost the function of the ringer mute and volume buttons on the side of the phone. Is there something in the battery replacement process (everything seemed to go without a problem) that could cause this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi Joseph, I would verify that all connections are being made correctly. Try disconnecting the battery, power draining the device by holding the Sleep/Wake button down for 5 seconds, check LCD, and Audio cable connections, and then reconnect the battery. Check to make sure that the flex was not damaged during the process by either heat or knicked by a pry tool. I hope this helps you out.
Best of luck, Alec
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Joseph Wolf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 83
