Zum Hauptinhalt wechseln
iPod Classic der 6. Generation. Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarze oder silberne Vorderseite aus Metall
904 Fragen Alle anzeigen
Battery connector dislodged, pins apparently left unharmed
Took me ages to get this thing to snap open, and now it looks like I ruined the battery connector while trying to release the brown thing keeping the cable in place. Just after I had finally managed to get around that cursed metal casing... I tried putting the socket back and it seemed ok, but nothing happened when I reattached the battery flex cable. Is this something I could realistically fix at home? I’ve read nasty stories on ifixit involving soldering the PCB (or just replacing it altogether) and I really wish there was a simpler way to put it back on track. I don’t see any pins stuck inside the plastic part btw. Thanks! https://imgur.com/a/RhRDDU7
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
try putting the battery connector back on with respect to the appropriate position if u can’t turn the device on
you can get battery connector here http://s.click.aliexpress.com/e/bJSBFSxA and make a professional do the soldering for you cause i messed up two ipods the same way thinking way over confident of my solder skills.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Antônio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 50
