Washer not working/just hums
My Kenmore 11020902991 fills then does nothing/hums
Ist dies eine gute Frage?
check the drive belt or the motor coupling. The humming noise could be caused by the motor working but not driving the transmission. If the motor hums but does not turn, check the motor start capacitor.
War diese Antwort hilfreich?
Carbon brushes in the motor: If you switch on the machine and it makes a humming sound as though it is working but the drum does not turn, then the most common explanation is worn out carbon brushes in the motor. ... Washing machine pump: The gentle humming noise may be caused by a jammed pump trying to turn.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 3,607
