Zum Hauptinhalt wechseln
Released in 2015, RX100MA Model IV, 4K Cyber-shot digital camera
8 Fragen Alle anzeigen
Dropped camera now it won't turn on.
I have just purchased a used Sony rx100 Iv that will not turn on. The previous owner says the device was dropped and after that wouldn't turn on. Any idea what could be weong?
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare
So I fixed the camera. I am not to sure what actually fixed it but I just fully disassembled the camera and reassembled it and now it is working.
von
cellphonebuyer1 excellent! Sometimes just reseating things can fix slight misalignments
von
@cellphonebuyer1
cellphonebuyer1 how much did you disassemble the camera? I have the same problem...
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
cellphonebuyer1  this could be related to a battery issue, check the battery contacts and do not forget the battery door. It could also be an issue with the main board and dislodged power flex. Sony’s camera all pretty much come apart the same way. Take a look at these guides and see if you can disassemble your camera. take plenty of pictures when you do so and post them with your question. that way we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hello, which flex cable is the power flex?
von
Step 16 and 17 in the above named guide show the ribbon cables. You will have to disassemble your camera and take a look at all of them.
von
Did you turn it on and try it out before buying it? If not, then I would say that it was broken when it was dropped. Even if you did turn it on before buying it, it is still possible that it was broken when it was dropped.
Bewertung 0
old turkey03 did you fix your camera. I am scared to try
Bewertung 0
Antwort hinzufügen
cellphonebuyer1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 40
Insgesamt: 4,437
