broken non fixable charging socket
my ipad air had problem with charging socket. made the test and found out that i needed to change charging socket. i changed it once then same. but i think i made a bad job. probably i damaged the charging socket on the motherboard. ipad working fine. but charge finished. i need to find solution for charging. and maybe speakers also, as speakers are on same flex cable.
how can i make direct connection from charging socket to motherboard by putting 2 cables direct to charge. and also for speakers. i dont bother about data transfer. i can use icloud or google for that or wireless.
does anyone knows?
thanks
Update (07/12/2018)
i think i damaged here so even i solder new socket here. it wont work. i tried 2 times. the pads on the picture
Ist dies eine gute Frage?
