Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zum Auseinanderbau für Lenovos dünnes und leichtes ThinkPad X1 Carbon Business Laptops.
65 Fragen Alle anzeigen
Error 2100 - HDD - Lenovo X1 Carbon
Hello, i need urgently help. Yesterday evening my laptop was off because battery was low. When i put it on adapter and try turn on it i saw just thinkpad screen and then error 2100.
I try reset it few times, then remove and put it back ssd disk but still same... some ideas ? I have really problem now because i am away from home , I don’t have second laptop and i hope that ssd in laptop not will be demaged because data inside are so important for me.
Thanks for help !
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
SAME ISSUE i HAVE 2100 ERROR HDD NOT DETECTED BUT I HAVE 2.5 SANDISK SDD . I AM STILL HAVE THIS ISUSUE. I PUT SPARE HDD IN LENOVO IT WORKS. ALSO WHEN I PUT IT AS EXTERNAL USB SAME NOT DETECTED.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi,
Try applying a bit of pressure with your fingers on the laptop base above where the SSD plugs into the systemboard and see if the SSD is detected on startup.
Bit hard to explain exactly where but here is an image of the SSD location, taken from the service manual, (p.58), so hopefully you can work it out.
(click on image to enlarge for better viewing)
If the SSD is still not being detected by trying this, you may have to try inserting another SSD to determine whether the problem is in the SSD or in the systemboard
If it is being detected when you do this then perhaps the motherboard SSD connector contacts or the SSD board contacts may be dirty etc. I realize that you have removed and replaced the SSD and usually this will clean the contacts but if it does detect the SSD by doing this then obviously there is something wrong that need to be further investigated
With a strong light and a magnifying glass, visually inspect the SSD connector on the systemboard (and also check the SSD connector contacts) to ensure that it is OK and does not appear corroded etc
If the systemboard connector contacts appear corroded etc, and you want to clean them (Isopropyl Alcohol 90%+) ensure that you disconnect the battery from the systemboard before doing any repair work.
War diese Antwort hilfreich?
Bewertung 2
Try this out: https://pcsupport.lenovo.com/us/en/solut...
Bewertung 0
2 Kommentare:
How i can update firmware when is laptop “dead” ? I can get just to BIOS
von
Flash bios with usb
von
Hi @Youssef Alberta
If the SSD is not being detected when either in the laptop (can you try another SSD or HDD in the laptop to ensure that it is working OK?) or in an external caddy connected to the laptop (did you try it with another PC?) and you know that the caddy also works (can you try it with another HDD or SSD?) then there is a problem with the SSD.
Basically you have to prove what is working and what is not working i.e. is the laptop sata port OK? Is the external caddy OK? If yes to both then it is the SSD
If the SSD is new take it back for a replacement.
Bewertung 0
Antwort hinzufügen
dominicxxx1999 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 4,752
