Zum Hauptinhalt wechseln
Kia introduced the second generation (JB) in the early 2005 model year in Europe and for model year 2006 in North America, based on a redesigned platform shared with the Hyundai Accent.
14 Fragen Alle anzeigen
How to check if my 2007 Kia Rio base model cooling fan works?
How do I check if my 2007 Kia Rio base model cooling fan works? We are replacing the radiator because of a "bug puncture", but the fan doesn't seem to be running either. Is it suppose to run all the time or just when the car heats up?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Electric engine-cooling fan motors only run when the thermostat opens or coolant temperature reaches a set temperature.
So no, it doesn't run all the time.
edit: to check the operation of the cooling fan, with the radiator fixed, let the car run for 5-10 minutes, this should be sufficient for the engine to heat up and meet the criteria for the fan to start. Just keep an eye on the intrument-cluster for coolant temperature so that it doesn't overheat.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
reneesown2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 1,045
