Zum Hauptinhalt wechseln
Why are my beats x not turning on
My beats will flash white 3 times and appear red when on charger indicating they are charging but they won’t turn on please help I’ve tried resetting but it does not work and the guide on reddit was way to complicated
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Beats x on charger ….keeps blinking red to white ……will not turn on
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I would try updating them. It might be a simple software issue. Otherwise it would be that the port is damaged.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I’ll check to see if that works thanks for the help
von
I tried updating them and I know there charging because the light turns on and the firmware update didn’t work
von
Same issue. Apple support says they are defective and wants $80 to replace them since mine are 14 months old. Crappy product and poor support.
von
Mine are still under warranty I got em in December
von
You are a doughnut fool !$$&* you need to use a Samsung charger not an iPhone charger go to auction to get a username which has £200 minutes in the account mohamedrashid00
Bewertung 0
Antwort hinzufügen
Silentgunner COD wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 18,317
