Zum Hauptinhalt wechseln
Repair guides and support for a wide range of welding machines.
Plasma cutting depth and thickness
I'm trying to open a old safe I found in a building that my company was raring down and its older safe over 350 pounds I've got a plasma cutter 60 amp it says it cuts 1 inch steel as so manybinch a hour
My question is that and will a plasma cutter cut deeper and deeper but it will make the cut slower and very ugly?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I have heard of some older safes containing materials that you don’t want to mess with if you are a novice. I would consult with my local locksmith who I know to be an expert on older safes. Can’t answer your questions regarding plasma cutting equipment however. Movies tend to make stuff look much easier than it in fact is.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
stephen kealey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 159
