Computer Will Not Boot in any Mode
I have tried resetting ram and smc.
I was using garageband when my computer froze all of a sudden. the music kept playing it was eerie. I force shut down and computer no longer boot up in any mode. after I did the ram and smc resets, I tried to do recovery (and in verbose) and I get a log that says disk0s2: media is not present.
failed to open swap file 6. va_swap_create_file failed.
then goes to a bright screen. I turn it off at this point.
If I allow it to try to boot normally or to recovery it just loads for a long time til it gets halfway and it appears to stop there so I cannot access diskutility.
Is this the ram failing or the hard drive failing? Thank you for your time and input.
Chris
Ist dies eine gute Frage?
Do you still have the grey disks that came with your system or the retail copy of OS-X?
If not, do you have access to another Mac and a USB or FireWire drive so you can create a bootable drive?
Some how you’ll need a means to boot up you system to fix the drive and you may need a new drive.
von Dan
