Step 1: Start Word.
To do this, follow these steps:
a. Click Start, and then click Run.
b. In the Open box, type winword, and then click OK.
Step 2: Locate the Word document that you are trying to open.
a. On the File menu in Word, click Open.
Note If the Open command does not appear on the File menu, do the following. Notice the arrows at the bottom of the File menu. Click these arrows. This will expand the menu and display all the menu commands.
b. In the Open dialog box, locate your Word document. Then, click to select your Word document.
c. Click the arrow next to the Open button, and then click Open and Repair.
d. you can try to use repair word document, it's a very nice paid service
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Sounds like the program obfuscated the file. The file itself is not damaged but been encrypted so the user cannot have access to the contents until you pay for the software. Is this a .doc? What program did you use to create this file?
von Angel Decoded (gellegbs)
