Zum Hauptinhalt wechseln
Ein Desktop Computer ist stationär und in einem Gehäuse untergebracht, getrennt von Peripheriegeräten wie Maus, Tastatur und Bildschirm
20 Fragen Alle anzeigen
Vertical Lines Take Over Dual monitors
So I am watching Netflix when suddenly both of my monitors are filled with Vertical Lines that block anything else from being seen. Both monitors are attached to a single AMD R9 270X video card and all drivers are updated. This has never happened before and there are no known new factors to consider that i am aware of.
Antivirus running : Avast
Windows Event Viewer does reveal errors relating to DistributedCom, however these are not new.
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user AMDHEXCORE\*removedpersonal* (S-1-5-21-785143520-4081613720-3159157434-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
====================DxDiag====================================
System Information
Time of this report: 7/19/2018, 21:52:05
Machine name: AMDHEXCORE
Machine Id: {EB297533-DF74-4081-900E-218721F97979}
Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release_svc_escrow.180502-1908)
Language: English (Regional Setting: English)
System Manufacturer: MSI
System Model: MS-7693
BIOS: BIOS Date: 10/08/13 16:03:23 Ver: 04.06.05
Processor: AMD FX(tm)-6300 Six-Core Processor (6 CPUs), ~3.8GHz
Memory: 8192MB RAM
Available OS Memory: 8142MB RAM
Page File: 5072MB used, 15068MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Sound Tab 6: No problems found.
Sound Tab 7: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon R9 200 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6810)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_6810&SUBSYS_92751682&REV_00
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 6098 MB
Dedicated Memory: 2028 MB
Shared Memory: 4070 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Extend
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.640148,0.340344), Green(0.279797,0.619641), Blue(0.140148,0.069836), White Point(0.310070,0.330578)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: DELL E173FP
Monitor Id: DELA00B
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HDMI
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\c0328911.inf_amd64_a81756cbffedb936\B328940\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0328911.inf_amd64_a81756cbffedb936\B328940\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0328911.inf_amd64_a81756cbffedb936\B328940\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0328911.inf_amd64_a81756cbffedb936\B328940\amdxc64.dll
Driver File Version: 24.20.11016.0004 (English)
Driver Version: 24.20.11016.4
DDI Version: 12
Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 5/15/2018 7:00:00 PM, 2023720 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71EE2-2B50-11CF-3675-7D99BBC2D535}
Vendor ID: 0x1002
Device ID: 0x6810
SubSys ID: 0x92751682
Revision ID: 0x0000
Driver Strong Name: oem77.inf:cb0ae4140a32e68b:ati2mtag_R575DS:24.20.11016.4:pci\ven_1002&dev_6810&rev_00
Rank Of Driver: 00D12000
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT
Deinterlace Caps: n/a
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Color Primaries: Red(0.636242,0.330578), Green(0.304211,0.629406), Blue(0.154797,0.070813), White Point(0.313977,0.329602)
Monitor Name: HP W2082a LED Backlit Monitor
Monitor Model: HP W2082a
Monitor Id: HWP325C
Native Mode: 1600 x 900(p) (60.000Hz)
Output Type: DVI
DDI Version: 12
WHQL Logo'd: Yes
Vendor ID: 0x1002
Device ID: 0x6810
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
Card name: AMD Radeon HD 7700 Series
Chip type: AMD Radeon Graphics Processor (0x683D)
Device Key: Enum\PCI\VEN_1002&DEV_683D&SUBSYS_25561458&REV_00
Display Memory: 5074 MB
Dedicated Memory: 1004 MB
Current Mode: Unknown
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
DDI Version: 12
WHQL Logo'd: Yes
Device Identifier: Unknown
Vendor ID: 0x1002
Device ID: 0x683D
SubSys ID: 0x25561458
Revision ID: 0x0000
Driver Strong Name: oem77.inf:cb0ae414858224dd:ati2mtag_R575ADS:24.20.11016.4:pci\ven_1002&dev_683d
Rank Of Driver: 00D12001
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
SO i Uninstalled the drivers and reinstalled a fresh copy of the Video Drivers and since i have not had this happen again.. best i can figure is that the driver management software must have incorrectly installed it… this is solved..
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Raymond Euerle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 112
