Zum Hauptinhalt wechseln
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 Fragen Alle anzeigen
home button reassembly questions
Hi all , im having a bit of trouble with getting the home button assembly back on a new screen of this ipad mini 4 i have here .
I fitted a new gasket with the home button ok but the bracket i cant seem to align it so the home button clicks , the home button does still click out of the frame , but im not sure if it's because the tape i stuck the bracket back on with is not strong enough as it does flex a bit .
Also the plastic spacer ring , i assume this fits between the home button and the bracket but does it sit on top of the flex or under it ?
I have some of this tape https://www.amazon.co.uk/gp/product/B00B...
on the way ,hopefully it will be stronger than what i have here , i was thinking of also adding a few drops of hot melt glue for extra support , is that a good idea ? .
any advice appreciated ,
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Perhaps the double sided tape is too thick and lifting the back bracket by a small enough fraction to cause issues. You could try to bend the bracket a bit so that it swoops down and forces contact with the actuator.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
markparnell1972 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 70
