Fridge defrost timer wont advance
Defrost timer wont advance. I can manually put the timer into defrost mode and it will defrost and put itself back in cooling mode, but wont advance back to defrost ever. I dont think its the timer itself as I have tried about 3 new timers and the same thing happens. What would cause this?
Ist dies eine gute Frage?
6 Kommentare
Im looking for real answers, not copy n paste. If you read the post you would see its none of the stuff you copy n pasted. thanks
von william holmes
William READ cause #1.
von mayer
I have the same problem and I can’t find an answer
von abdulrahman albahith
I have the same problem, the timer sends power to the heater during defrosting period(21 min) and after defrosting time it advances to cooling it takes longer time not advances to defrosting again .What is the solution for such issue?
von Abdullah Altarouti
SOLVED: I had this same issue with the defrost timer not advancing to defrost mode. In the past, I had to manually turn it into defrost mode and the timer would advance only out of defrost but never into it resulting in ice build up preventing proper air circulation to the fridge. TURN THE TEMP DIAL DOWN! My temp dial was overriding my timer so it always stayed in cooling mode and never went into defrost mode resulting in ice buildup and the prevention of proper cold air to the fridge.
*multiple defrost modes or the manual melting of ice build up is reccommended before lowering the dial for quicker results*
von lageta826
1 weiteren Kommentar anzeigen
