Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
New screen, but no display (phone powers on and touch work)
Hello,
I have replaced my broken screen with a new one and
I still have no screen, what else can cause the screen to be completely black?
I can tap, I can hear sound coming out from the device.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
*The screen went black upon breaking the screen
*Sound and the vib doesn't seem to work when the old screen is plugged in
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Did you disconnect the battery prior to removing and installing the replacement screen? Not doing so can cause the backlight filter to blow and the iPhone 6S is particularly prone to this issue. The best way to test for this is to shine a bright light on the screen immediately after powering on the device. If you see a dim image, the the backlight is defective.
This could also be caused by a defective screen, as the others have suggested. The way to test for this is to re-install the original screen. If the original screen works, then you have a bad replacement screen )or connection issue). If the original screen does not light up either, then you blew the backlight circuit on the logic board. This requires a micro-soldering repair and is not DIY.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Yes, I did disconnect the battery before uninstalling and re-installing the new screen.
The original screen went black when it broke.
To confirm it is not the backlight like you said, I tried to shine a bright light on the screen upon powering the phone and I couldn't see anything.
von
Try reseating the connectors. If that doesn't work, you may have a bad display.
Bewertung 1
Roje ha,
It appears that you received a defective screen. Your best bet would be to call the company you ordered it from and ask for a replacement under warranty.
Bewertung 1
Antwort hinzufügen
Roje Ha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 247
