Zum Hauptinhalt wechseln
Haswell business laptop introduced by Dell in 2013. This system is notable for being the first Haswell business laptop released, but has multiple known problems - including AMD GPU failure. A new battery will operate the laptop for ~4-7 hours, depending which one is installed.
replacement keyboard not working
Hi there,
I have recently replaced my keyboard with a non-original keyboard and it works only a few minutes and stops. After every BIOS update it works again and stops after a few minutes.
Any idea how i can get this non-original keyboard to work?
Regards,
Siviwe
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
You tried to use your keyboard in safe mode if it is working then there must be an app causing error
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Need to try a DriverPack Solution Software and update the keyboard driver. If the problem persist your new keyboard might have a defect.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Siviwe Xegwana wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 328
