What is wrong with my truck
So I have a 1992 k1500 5.7 tbi I bought from a friend, had a fuel problem creating a decent loss in power and stalling in low idle range as well as when the truck was coasting, replaced the fuel filter and MAP sensor which helped a little, stopped it from stalling at low idle range for the most part and no longer stalled while coasting, was going to replace fuel pump but fuel pump relay as well as fuel filter had been brand new so I I’m assuming fuel pump is as well since some work had been done to it prior to me getting it, I then proceeded with replacing spark plugs, wires, distributor cap and rotor as well as ignition coil, which leads me to how the truck is now, it acts as if it’s misfiring and runs incredibly rough, I have to hold the throttle open to even get it to start, I just finished rebuilding the throttle body and replaced the fuel regulator inside, no change at all, iv triple checked my wires and they all go to the correct places, spark plugs properly gapped and everything properly connected, no clue what my problem could be, any help is appreciated
Ist dies eine gute Frage?
