Zum Hauptinhalt wechseln
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why one of my propeller not working?
I have a DX-2 stunt drone. one day it fell from 10 feet fall to the grass. Then one of the propeller stop working I was surprise because it survive alot worst crashes. what should i do? i just want to know if i can fix it before i got buy a new one.
Ist dies eine gute Frage?
Bewertung 9
5 Kommentare
Did you ever get an answer? I have one doing the same thing. New motor doesn't fix. Same issue
von
my one of my propeller does not want to start on my dx-2 stund drone
von
my propeller won't work and the wings are too hard to fit on there they are a little too small to fit.
von
same problem and im pritty sure it is because one of the motors died out and I'm trying to fix it so I took off the propellers and felt the tip of the motor and it seems it's borken and I need a new motor or drone
von
or cricket bord or wires
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
you may need to order a rotor replacement for the drone, look at the manual for details where to get one
War diese Antwort hilfreich?
Bewertung 3
mabey get either a new motor or take the blade off and put back on and then try
Bewertung 1
it is because you either need a new motor or you just need to put on new propellers if that does not work, sorry just keep looking.
Bewertung 1
3 Kommentare:
The reason why you need to add a new propeller is because when the wing is cut on something but the motor is still spinning it will smooth it out so it has no grip on the wing.
von
i believe this to be true. My grandson got his for xmas a day ago and can't use it already. i feel that the motor is functioning but the blade to shaft connection isn't secured.
von
consistent flying at high speed could be your problem the shaft from the rotor heated and expanded your wing base
von
Yeah its something with the connection from motor to blade. Like a gear slipped. I am trying to find something that illustrates the inside and how to open it
Bewertung 1
one day I crashed my dx-2 sharper image in to a river and it will not work so how do I fix it
Bewertung 0
Antwort hinzufügen
Majur GonZolaz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 48
Insgesamt: 8,749
