Zum Hauptinhalt wechseln
{A1706 / EMC 3071}—Veröffentlicht im Juni 2017. Dieses 13" Macbook Pro ist mit Kaby Lake Prozessoren bis zu 3,5 GHz Core i7 mit Turbo Boot bis zu 4,0 GHz ausgestattet.
276 Fragen Alle anzeigen
Do the speaker grills on the right side upper part pass through?
I had a question before about a coffee spill on my MacBook Pro 2017 with Touch Bar.
I came across some photos from the IFIXIT teardown that stated that the grills holes don't pass clear through to the inside at the upper part specially, does this mean that no liquid can pass through it at all and that it's completely obliterated?
Image 1
Also can somebody tell me what are the two white rounded rectangles shown in Image 2
Image 2
Can somebody please confirm this information?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The grill holes at the bottom of the image are through hole so the sound can pass through. The upper part is done for aesthetics (look). So anything that leaks through the lower part will wet the speaker.
The holes in the second image you are seeing are the USB-C holes in the case. The USB-C connectors pass through these holes.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Dan thank you very much for your reply, so that means that if I dropped two drops on the upper part like beside the “delete” button this holes are a dead end and they don’t lead to the inside of the macbook at all and If i cleaned it right away I’m safe right ?
von
Can't make that promise, but it's a good likelihood ;-}
von
hahahaa come on, why can't you make that promise, man ?
okay let me ask one straight questions :
The speaker grills at the whole upper part , except of the lower part shown in the image, do not pass through the metal body of the macbook ? yes or no ?
von
The upper holes are for show! Only the lower holed part (what light can shine through) are through.
von
okay thank you man so much
von
Antwort hinzufügen
Peter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 840
