Zum Hauptinhalt wechseln
Erschienen im März 2017, ist das G6 LGs Flaggschiff-Smartphone mit Android 7.0. Dieses Gerät ist bei den meisten Händlern erhältlich. Eine Reparatur dieses Geräts kann die Wasserdichtigkeit beschädigen und das Gerät anfällig für Wasserschäden machen.
56 Fragen Alle anzeigen
Dropped my phone in sea water, now it won't turn on
I dropped my LG G6 in sea water and it was retrieved after half an hour. Now it won’t turn on. I tried cleaning the ports and drying as well. It has been 5 days already since the phone was dropped in water. Would it be possible to retrieve the photos from the phone if I took it to a technician?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
After 5 days, you’re odds are getting lower and lower. If you want to try something yourself, then do the following:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
 A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thank you very much for the detailed response!
von
Antwort hinzufügen
Tingu Pingu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 225
