Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
How much of my iPhone can I soak in alcohol to remove salt?
I dropped my phone in salt water in a remote location and can only now (12 days later) try to repair it.
I managed to remove the battery from the iPhone right away using some really really DIY tools (steak knives) without damaging anything except for scrunching up the covering on the battery in the process.
I have ordered and received a ifixit battery replacement kit and a bottle of 99.9% alcohol. I have removed all parts from the phone that could be removed without removing adhesives (excluding the buttons as they look fine).
How much of my phone can I soak in alcohol to rid it of the salt?
I’ve read the the screen can be damaged by putting it in an alcohol bath. Given that there is salt in many parts of the phone (it seems the salt water didn’t get in everywhere though), how likely is it that I’ll manage to fix it myself?
How likely/expensive (an estimate) is it to have it fixed by a repair shop if it doesn’t work after trying myself? I can post images it necessary.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Take a look at this vid: How to Professionally Repair iPhone Water Damage
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So you're saying that at this point I should bring it to a professional right away and hope for the best? Should I clean other components as well? What components are safe to put in alcohol?
von
They have the skills and if needed access to replacement parts.
von
Antwort hinzufügen
douira wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 263
