Zum Hauptinhalt wechseln
Das 2-in-1-Notebook Dell Inspiron 15 7579 wurde 2016 veröffentlicht und ist an seiner Modellnummer 7579 zu erkennen. Es gehört zur Inspiron-7000-Serie von Dell.
I cannot unplug the battery connector
Hi,
I’m trying to unplug the battery from the laptop to work inside it, but the connector just won’t come out. I’m pulling pretty hard on the cloth part of the connector, but all I manage to do is detaching the cloth from the cable.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Did you manage to unplug the connector? Because I have the same model and looking to order a battery and replace it myself.
von
I eventually did, I don't really know how or why, it just finally accepted to come out. I think I might have used tweezers to grab the connector from the sides and pulled it out. What I know is that when you apply force on it at the correct angle, it is not even that hard to remove, you don't have to pull like crazy and tear the cloth like I did.
von
I cannot plug it back in, help!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This model has a flush type of connector. So you need to slide it out like how you would slide a letter out of a envelope (don’t pull up!) Once the connector has cleared the logic board connector you can then pull up.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Loris Mendolia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 39
Insgesamt: 3,820
