Zum Hauptinhalt wechseln
The Canon PowerShot A720 IS is a point-and-shoot camera with 8.0 megapixel resolution and a 6x optical zoom.
12 Fragen Alle anzeigen
Will not hold time and date
When I switch the camera on, the set time and date message comes on the screen. This has to be set before the message clears from the screen. The next time the camera on you have to go through the same procedure again.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I have a similar camera (A570 IS) and mine has a second type of battery right beside the two main AA ones. It’s under a cover marked “CR1220” which refers to the type of that second battery. Pull that cover up, replace the CR1220 (or whatever battery type your camera has) and that should fix the problem.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
i tried that and it didn;t work
von
@williams679 what make and model camera? what were the issues and what did you try?
von
Hilfreichste Antwort
If the battery level drops to low, a board will lose its memory. Replace the battery.
Bewertung 4
1 Kommentar:
I have already replaced the batteries but problem still exists.
von
Antwort hinzufügen
rogerdeans wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 968
