Zum Hauptinhalt wechseln
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554 Fragen Alle anzeigen
blades diaengage and battery dies
Hello, I have a craftman 46 inch pro series riding lawn mower. It wouldn't start even after charging battery. Changed battery, cut 1 acre just fine, midway through the next cut the blades would disengage, engine would rev a little faster and the steering would get tough. Turned mower off and wouldn't start back. Put on charge for about 30 mins, mower started back up, ran for about 10 mins and I repeated the same process 2 or 3 more times until I finished cutting the yard. Any thoughts?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Sounds like the battery is not getting charged. Check across battery terminals with it running at cutting speeds you should be getting 13.5 volts if not then the charging circuitry is to blame..
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
ok, I will do that tomorrow. If its not reading 13.5 then what in the charging circuitry needs to be replaced
von
battery not charging at all
Also you need to provide model number and serial number info here and at Sears when you order the parts or we will only be guessing otherwise.
von
Antwort hinzufügen
ryan sparks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 103
