Zum Hauptinhalt wechseln
The BLU Life X8 is an unlocked Android smartphone (similar to the BLU Life 8 or BLU Life XL) that was released in July of 2015. It can be identified by its Global Trade Item Number 00848958020011.
6 Fragen Alle anzeigen
Phone over heats/broken micro SD card
How do I remove the broke piece of micro SD card still inside?
Second question is there a setting to control app permission to stop apps from having access to everything as the phone gets to hot to hold?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sometimes these can be removed using fine tweezers or razor blade depending on how the SD card slot is covered.
It’s probably the broken microSD card causing a short-circuit on the phone making it heat up a lot.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Stev Reid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 50
