Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1364 Fragen Alle anzeigen
home button ring is raised from top
hey guys I have bought a 7 plus yesterday and what I have noticed is that the ring on the home button is a little bit raised or sticking out on top and perfectly aligned on other sides, it works fine though the touch, the taptic engine. I have a 7 also but it is fine, also the sim tray is not original it doesn’t have a seal on it. the main concern is TOUCH ID. Should i return the phone and get other one or is it okay and I continue using it. will it get damaged or failed?
its so much minor that I could only feel it by swiping my finger over it and by looking very closely to surface I can see it a bit raised on top …
Please describe the best solution
Thanks in Advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
I think it should be fine. Maybe its a refurbished unit from a local shop and the screen had been replaced.
War diese Antwort hilfreich?
Bewertung 0
This sounds like a privately refurbished phone, do not consider it be new or waterproof or perfectly repaired.
If you bought it for cheap “as is”, I guess it’s OK. If you bought it as “new” or “almost new”, talk to the seller.
Bewertung 0
I would honestly just re-seat the home button as it is possible to get a pressure crack and loose certain functions. If the phone was refurbished and the screen was replaced, there may not have been enough attention to detail when seating the home button.
Bewertung 0
Antwort hinzufügen
Sania Nadeem wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 436
