Zum Hauptinhalt wechseln
Die Xbox Spielkonsole der dritten Generation von Microsoft kam am 22. November 2013 auf den Markt;
727 Fragen Alle anzeigen
How to repair motherboard.
I had an Xbox One with motherboard problems last year and because I didn’t knew that you can fix that kind of stuff (now I know you can at least try), I just simply bought a motherboard from the ifixit store and replaced it.
I don’t have that xbox anymore but still have the motherboard with the paired optical drive and it goes against every fiber of my being to just throw it in the trash, is there something I can do to make it work again and try to recover some of the money I spent?
(sorry if my english is bad)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
With the right equipment and time, anything can be repaired (unless there is a hole in the board…). Trying to erpair a singular board without the rest of the unit will be tricky at best. What was the original problem? This too will determine whether or not the repair is feasible.
If there are clear parts that are damaged, replacing them should be fairly easy. Just replacing the known bad parts may not resolve the problem unless it is known that these are the only problem. There may be hidden issues that caused these parts to fail that must also be addressed.
The bottom line is that your question is not easily answered. There are too many factors not known.
Hope this helps,
Dan
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
The original problem was that the console was plugged in during a thunderstorm. The power supply was fine but the console wasn't going to turn on. What is your suggestion? I can upload pictures of the board if you want or if it is going to be useful.
von
Power surges are the most difficult to resolve since much of the damage is not easily found. If the power supply is good, then the surge ended up getting to the ICs on the board. If there are no visible signs of burned components, trying to find the problem will be extremely difficult. Since schematics are not available for these units, it is a guess as to what is not functional. Unless you want this to be a learning experience with changing components, this will be a big time sink. You will need to try and understand the circuits involved and guess the defective parts. I don't mean to sound discouraging, but having wasted time on similar projects in the past, I'm trying to be realistic. It can be done, but will require a lot of time and research.
von
Do you think it's worth the try? If it isn't then I just leave it like that.
von
Hi I’ve damaged the motherboard on my xbox one x. Removed components to add thermal compound and by prising the silver cross held by clipped screws I can see I’ve have broken a piece of soldering on the other side. Is there a way I can repair this as my xbox wont turn on, it beeps and thats it? I have solder and solder gun. This is what happens when you follow one youtube guy that doesn’t do it properly
Bewertung 0
does any one know what this chip is on xbox one x motherboard because mine has blown trying to find out what it is
Bewertung 0
Antwort hinzufügen
fede wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 4,055
