Zum Hauptinhalt wechseln
Repair information for the Beats Studio 2.0 wired headphones. Originally released in 2013. Model number: BT OV STU BLK.
88 Fragen Alle anzeigen
Beats Studio broken headband stuck in hinge
I am trying to fix Beats Studio 2.0, but don’t know how. I have already purchased new ear cushions and headband. Problem is that there are broken headband pieces in the right hinge, preventing its ability to fold. How can I remove the broken pieces in the hing? Much appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
How would I get the plastic piece out? The plastic is still stuck in my right hinge and I cant get it out what should I do?
von
Dude I tried pushing it from under and pulling it and it broke the tip of the blade I was using and no the wires are still good I don’t cut them
von
What did you do after yo popped the plastic piece off?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You can take a plastic spudger tool or a plastic razor blade or something similar, and stick them in the seam beneath the gold piece that says “Studio” and slide the spudger towards the driver and the plastic piece should pop out. Then you will be able to see the broken hinge part.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
This worked brilliantly! Thank you so much, you saved me a lot of money.
von
Antwort hinzufügen
costarico. ayy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 40
Letzte 30 Tage: 121
Insgesamt: 4,856
