Zum Hauptinhalt wechseln
Repair guides and support for Kenmore washing machines.
will not fill with water when set in cold
I have a series 100 Kenmore washer it will not fill with water when set in cold but works on hot and warm but does not fill up but half way or less what is this issue there us no water level setting
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Sounds as if your cold water valve is clogged. There's no way to work on the valve, only replacement will cure it. Call customer service and they will make it right for you under warranty.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
dwaynekmallory wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 30
