Zum Hauptinhalt wechseln
Modell A1418 / Ende 2012 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
212 Fragen Alle anzeigen
White screen, no chime, keyboard not connected
I saw similar questions but could not find the answer. I will try to give all details.
I had upgraded my iMac Late 2012 to SSD - Toshiba TR200.
With a Windows installation usb I had to format the drive first then with macOS boot usb I had installed High Sierra by choosing APFS file format.
I worked fine, opened normally, restarted normally, I had browsed internet etc no problems.
Then I had to reinstall High Sierra with a bootable usb for some reason ( i wish i had not).
On boot screen, instead of usb drive, I mistakenly selected third item, i do not remember its name. First was my harddrive, second was usb drive that should have been selected.
Now it stucks at white screen. No chime on startup. I hear fans. I wanted to try some startup key options but I think my bluetooth keyboard is not connected, because caps lock light does not work. I do not have a Apple wired keyboard but have a wired PC keyboard.
As a last try I have reopened and put my old HDD but it is same.
I would be glad if you could share any suggestions.
Thank you very much.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You’ll need to use the PC USB keyboard to gain access to the startup keyboard commands: Mac startup key combinations
Now you have a few choices here I would try Safe Mode first holding the Shift key to see if you can recover access to the drive. If you have a working bootable MacOS boot drive you could try to gain access via pressing the Option key. In a windows keyboard the mapping would be the Windows Icon key.
Your last hope is to use Command (⌘)-R to reinstall the OS from either the hidden recovery partition if your drive has it still or to via the internet (you do need to be connected). As your internet maybe slow at home you might want to just bring your system into an Apple Store to let them help you.
Reference: Keyboard mappings using a PC keyboard on a Macintosh
War diese Antwort hilfreich?
Bewertung 1
8 Kommentare:
Thank you. I have tried the keyboard combinations (Shift, Command, Command+R,Alt), SMC reset but still same.
von
Can you get into Target Disk Mode? Holding the T key? You should see a Thunderbolt Icon dancing across your screen.
von
By the way I have just noticed that while in white screen with wired usb keyboard connected, caps lock light is not working. So does it mean my imac does not recognize wired usb keyboard?
I know it is working by testing on my laptop.
It is Microsoft's wired usb keyboard.
Thank you.
von
So did you get the icon showing your on the screen?
von
No, unfortunately
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
Erdem Akkaş wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 488
