Zum Hauptinhalt wechseln
This is an ASUS laptop with a 15.6 inch monitor released in 2014, identified by part number R510LA-RS71.
ASUS R510L screen not switching on after motherboard replacement
Hi,
I have ASUS R510L that I' have change motherboard. Everything is working except the screen. When I connect to external monitor, I get output correctly. So my issue is with the screen. Also the computer fails to reset surely for I already upgrade from windows 8.1 to windows 10. I tried static energy discharge (holding power button for 30, 60, 120 seconds etc.) still can’t get the screen run up.
Any Guru advice to fix up will be appreciated.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Check the connection from lcd to mobo is secure, it needs to be making good connection to get output to the display.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Tkx @Minus. I've tried a lot of time but still not working. However, I ordered another cable connector hoping that is the issue, for the screen itself doesn't seem to have any flaw.
tkx again.
von
Antwort hinzufügen
Jaures wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 222
