Zum Hauptinhalt wechseln
The Sony Xperia C is an Android phone which was released in July 2013. It features a 5.0-inch display with a ~220ppi density and an 8MP rear camera. The Xperia C can be identified by the model number C2305.
Why is Xpreia C4 shuting down itself while moving it.
Hello. Xpreia C4 is shuting down itself while moving it. Battery is full, but phone is shutdown itself  while i am moving the phone, while turning it in my hand or walking with it in my pocket... After shutting down, it isn't starting itself. I cannot start it with button also... I waited 1 week, then tried to start. it started. But while again i move the phone in my hand, it shuted down itself again... huh... what may be the problem. Anybody knows?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi Talha,
Your Sony Xperia C4 automatically shuting down does not necessarily mean that it has a problem. There are many possible causes for this phenomenon.
  1. The battery is defective - In cases where your telephone is old enough, it is feasible that it’s the battery. You can do a test with a secondary battery if you have. In the event that the problem persists, go to the store.
  2. The battery is improperly calibrated - To resolve this issue, you will need to let the Sony Xperia C4 totally unload. Once it is carried out take out and replace the battery in cases where feasible. Then connect it to charging and let it charge to the highest possible.
  3. Android is not up to date - If your telephone is out of date, it’s sometimes likely that your Xperia C4 will go out on its own. You ought to therefore examine that your phone is updated.
  4. Application - If your Xperia C4 always turns off when you use the same app, this means that the problem originates from there. All you have to accomplish is uninstall the application in cases where it’s.
I hope it will work.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tâlha Mesud wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 652
