Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 11" MacBook Air enthält Intel Core i5 und i7 Prozessoren der 5. Generation, was die Leistung und die Akkulaufzeit etwas verbessert.
122 Fragen Alle anzeigen
MacBook Air won’t turn on, freezing, crashing, spinning rainbows
MacBook Air purchased early 2015 won’t turn on,
I get a black screen with the Apple logo and a loading strip which doesn’t load. There is no water damage to the device but the hard drive is full.
Currently need the contents for Uni assessments. Have tried power cycling, SMC? Reset, holding shift, control and alt with the power key, holding command, power and the letters R and P, and holding shift and power which gives me a nearly full loading strip but unfortunately freezes right before success - so frustrating.
I have no tools to open things and I’m hoping to get it repaired before Tuesday (today is Saturday), any ideas welcomed.
TIA MShell
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Do you have access to a second Mac which you can interconnect your system to using Target Disk Mode?
How to use target disk mode to move files to another computer
If you can you should be able to gain access to the files, At least save your stuff. Then reformat the drive and re-install the OS. You should be able to recover your drive.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Thank you so much
von
The solid state drive has failed. Will need to replace and reinstall Mac OS
Bewertung 0
Antwort hinzufügen
SD Card wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 98
