Hi @binrintechy ,
Which light(s) blink on amber and white?
Try using a torch held at an angle close to the laptop screen (once the laptop has been turned on and you can see an image on the external monitor) to check if you can detect an image on the laptop screen at all. It will be very faint so perhaps in a darkened room may help.
If you cannot see an image on the screen, and as you have already replaced the display the problem is either a loose or fault video cable (check both ends), a fault on the motherboard or perhaps the new display is faulty.
If you can see an image on the screen, then you have a backlight problem.
This could be either:
a faulty backlight power supply on the motherboard,
a faulty backlight power cable to the display (looking at the service manual for your laptop, (taken from this webpage, it appears that there is no separate cable so the power may be supplied via the video cable - if there is only one cable it will be through the video cable),
a faulty lid switch. The lid switch is a magnetically operated switch that controls the backlight power. It turns “off” the screen when the lid is closed) It is usually a magnet in the lid (below the screen) operating a switch (somewhere between the top of the keyboard and the back of the laptop. Looking at the manual it makes no mention of the switch. Try using a magnet (reasonably strong) and moving along the top of the laptop case between the keyboard and the back edge of the laptop and check if you can “make” the screen come on. Do it near the Power button as the switch may be incorporated into the power button board. (not sure about this though)
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
