Zum Hauptinhalt wechseln
Whirlpool Quiet Partner 1 - only "Options" lighting up
Model # du1055xtss2
Dishwashing not running at all. The only buttons on the control panel that are lighting up when pushed are the 3 “Options” (Hi-Temp Wash, Sani Rinse, Heated Dry). The “Cycles” (Pots Pans, Normal, Light, Rinse Only) will not light up when pushed and are not functioning. The “Start/Resume” is not working either.
Wondering if it may be the thermal fuse or possibly the control panel itself. Hoping to avoid a service man repair cost. If help moving forward would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks. I did read that thread prior to posting but found it to not be relative to my problem. I’m having no issues with my latch.
I did try to reset by shutting off the breaker for 3 minutes. No change. The drain pump did not run after turning the breaker back on (something I was told to listen for). At this time, the only thing that is working are the lights on the control panel for the “Options”.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This question has been asked before. You want to try to reset it and possibly get it into diagnostic mode:
Dishwasher whirlpool quiet partner I push start button nothing happens
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
J. Horvath wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,135
