Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
220 Fragen Alle anzeigen
Recently replaced Digitizer Issue
I recently replaced the digitizer (iFixit part), it seemed to be OK but after a few minutes it starts to type on it's own or if you attempt to swipe to the next page it will swipe back. I have taken it apart and everything looks good. Is it possible it's a bad digitizer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
It’s possibly a digitizer issue as the iPad mini is notorious for those kinds of issues. iFixit mini replacement parts are quite good quality however so as Lee suggests, contact support to see what they can do for you. The iPad mini has a few gotchas as far as the digitizer goes, @jessabethany did a great write-up several years ago and it still applies today.
War diese Antwort hilfreich?
Bewertung 3
Head on over to iFixit support/warranty dept! They stand behind their stuff.
Bewertung 2
You need to locate two foam ridges on both sides of the home button on the housing chassis, they are adhered onto a tape that is holding the LCD, you can either pull off the foam ridges or scrape them off.
The foam ridges often interfere with touch functionality (especially when install an aftermarket digitizer)
Bewertung 1
Antwort hinzufügen
Jeff Poulin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 100
