Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
432 Fragen Alle anzeigen
Can I upgrade Core i5-2400S to Core i7-2600?
it is possible upgrade Core i5-2400S to Core i7-2600?
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
http://www.cpu-world.com/Compare/498/Int... has a comparison for both. Just does not look like a whole lot of improvement and checked the cost of the difference, seems steep for the difference. Good Luck
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
You can upgrade the 21,5" with the i7 2600S
War diese Antwort hilfreich?
Bewertung 1
As long as both are the same mount...
*After some googling*
They are both LGA 1155, so yes, it can be upgraded.
Bewertung 0
3 Kommentare:
Gabe - did you find anyone that has done this successfully? Just because a chip fits doesn't mean it will run.
von
Touché. Well theoretically, if its the same bus speed, etc, it will run? I vaguely remember someone upgrading their processor from 1066 MHz to 1333 MHz because the bus was on the processor on a mac once.
von
The i7 is sandy bridge and the i5 is an older process. I wonder if there might not be firmware problems.
von
OS 10.6.7 has to be able to support the intel core i 7 2600... google that first
Bewertung 0
Antwort hinzufügen
IntVar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 4,562
