Zum Hauptinhalt wechseln
Toy quadcopter with camera, controlled over Wifi by smartphone.
What is the best glue for repairing the expanded polystyrene?
Hi,
I have used the AR drone twice and have already caused significant damage to the expanded polystyrene - the piece the camera fits on has all but snapped off.
I have made the mistake of using polystyrene cement on it which DOES NOT work. This glue is meant for high density polystyrene; the cement melts lower density stuff.
I've had a look around and people seem to suggest all sorts of glues: epoxy, copydex, foam-safe superglue, etc...
Has anyone experimented and have a definitive answer?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
10 Antworten
Richard, I have NOT repaired any of the little drones :-) but here is a great read about the properties and the repair. Now if that is to much ;-) what I have done in the past to repair any polystyrene is to go to a model builder/kit builder store. Those places have the proper adhesive for your situation. Remember whenever you do a repair on it, you are dealing with nothing else but a styrofoam cup material. So if you are not sure about what to use, do not test it on your drone. Test it on a styrofoam cup, its a lot cheaper. PITA to control, is it?.....Good luck and I hope it gets fixed soon
War diese Antwort hilfreich?
Bewertung 0
I can tell you from personal experience... I have crashed the crap out of mine because I don't really care...hehe... Anyways... one word will help not just you but the WORLD!!! GORILLA GLUE (multi-purpose) ... a small bottle of it from the local drug or hardware store should cost less than $5 and I have made MAJOR HULL BREAK repairs (over 7 of them) and even used it to 'fill' in all the missing chunks taken out from the props on the inside of the indoor hull which I enjoy flying outdoors because it PHREAKZ people out more...and of course makes the more expensive parts not as vulnerable...BAM! There it is and to the entire AR DRONE community!!! KEEP FLYING AND YOUR WELCOME!!!
>>>--------> KiRBYdOoO
I almost forgot the most important part....ORIGINAL weight of the AR Drone with standard battery and indoor hull is appx. 433 grams...just shy of a pound. Weight AFTER over 40 repairs and 1/4 of a small bottle of GORILLA GLUE spread throughout the entire hull... 439 grams... it's a no brainer and its TOUGH and it EXPANDS and it HARDENS!!! I do have to mention though that it does expand quite a bit so you should use it sparingly and smear it all around into the actual gaps in order for it to take a proper grip as it will sometimes chip off. I also had to use my cordless rotary tool grinder to smooth out any glue (looks like spray foam gap sealer when dry) after it dried and expanded in the areas where the hull makes contact with the DRONE...including and especially the CAMERA tunner as the smoothness is important for many things that are irrelevant here. Again, have a great day flying this lovely deivce...I am!
Bewertung 0
Gorilla or other polyurethane adhesive will be messy for the reason stated previously.
I use "LOCTITE" Plastic Bonding System (bar code 79340 82565)- try Ace Hardware, etc. This works great if the directions are followed. If "chunks" are missing, bond together what you can, then prefit voids with wittled down bits of (black) EPP from another object, prime and glue accordingly. Any surface glue can blackened wih a permanent marker.
Bewertung 0
Stycon adhesive is a strong durable glue to fix polystyrene cornice to walls, ceiling, wood or metal. The adhesive can also be use to fix polystyrene ceilings to brandering. Stycon adhesive is sold in 260ml tubes and cost R14.50 per tub. One adhesive tube can glue between 8m to 10m of cornice. I mostly like Foam-Safe CA Glue and 5 min epoxy on my builds. Most of my foamies are built fast to get in the air as quickly as possible. If I had more patience and wanted to build a better looking model.
Bewertung 0
"UHU por" Glue is designed specifically for use with expanded polystyrene. I bought a tube last year and repaired a bashed up indoor flight cover, completely invisibly too!
KFS
Bewertung 0
Drone Glue on Drone360 is the best out there for binding plastics and frames. Also works with 3D Printed materials.
Bewertung 0
Hi, It seems like PVA is best if you may want to rework the piece or epoxy or builders adhesive (“no more”, or “sticks like” etc) if its a permanent job.
I Hope that helps.
Col.
Bewertung 0
I have had great success with a product called stick fast. It’s a 2 part adhesive. 1 part ca adhesive the other part is an activator. Just beware that once the 2 parts have met it’s a matter of seconds before it sets so have everything you don’t want stuck away. I wear rubber hospital gloves as I had to learn that lesson the hard way. Lol. I have used it to glue back together the main cross piece and the styrofoam. No melting no nothing but holding everything together and quickly at that
Bewertung 0
I do not stick any type of drone before, but I think Aleene’s glue can help you in this situation. It is a multi-purpose adhesive that can help you to any type of DIY art and craft.
The main advantage of this glue is, if you can stick it wrong place by mistake, then you can wipe it away with soap and water immediately. But, once it dries, you can not get rid of it.
Bewertung 0
Save money, I bought E6000 in Walmart. It works!!!
Bewertung 0
Antwort hinzufügen
Richard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 17
Letzte 30 Tage: 61
Insgesamt: 28,822
