Zum Hauptinhalt wechseln
A1418 / EMC 2833 / Ende 2015 / 3,1 GHz Core i5 oder 3,3GHz Core i7 Prozessor. Erscheinungsdatum 13. Oktober 2015.
96 Fragen Alle anzeigen
Boot problems, strange diagnostic leds.
My 2015 EMC2833 gave up on me and I don’t have a clue what it could be.
Are there any schematics available for this model? MB nr. 820-00431-A I have googled for a long time with no success.
I have removed the LCD to access the diagnostic leds.
When I connect power, both LED 1 and 2 lights up within 3 secs without me pressing the power button. if I push the power button the leds turn off and comes right back on again 2 seconds later.
But if I hold the power-button while inserting the power cable only led 1 lights up.
If I then release and push the power-button again led 2 lights up but no chime or fan-spin.
If I then hold the power for 6 seconds led 2 goes off and 1 stays on.
Why is there a difference if I hold power-button or not when inserting powercord?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
My computer don’t power up could be the problem. Maybe power supply
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
These are the symptoms of a blow power supply. Here’s the IFIXT guide you’ll need to follow iMac Intel 21,5" Retina 4K Display Netzteil austauschen and the needed part iMac Intel 21.5" (Late 2012-2019) Power Supply.
You may want to check your electrical outlet to make sure its grounded and the breaker panel ground connection is in good shape as well.
You might want to get a good surge suppressor or better yet a UPS as often a power disruptions or lightning kill the power supplies.
iMac Intel 21.5" (Late 2012-2019) Power Supply Bild
Produkt
$129.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kim Fossdal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 247
