Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
Touch screen unresponsive after replacement.
I recently replaced my touchscreen on my iPhone 4 following the guide on here since it was dropped and the LCD was fubar. After it's been replaced the LCD works but the touch sensor doesn't work. Is there any reason for this to happen? There were no issues with the removal and installation of the new screen only a couple of the screws were a pain. This is a 16 GB black model.
Any thoughts?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
There can be several issues:
  1. Connector of the touch is not connected properly
  2. Damaged the touch screen during installation (tare the fragile cable apart or maybe installed some screws wrong which caused the cable to get damaged
  3. Screen is DOA
Good luck!
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Who needs luck with a fixed/broken iPhone?
von
I already had this problem when disassembling the phone. In my case, I just cleaned (with alcohol) the digitalizer contact (both, the one at the PCB and the connector cable itself). After doin' it, I let the phone opened for a while to let the alcohol dry by complete. Touch sensor working fine since then.
As said before, don't forget to take a look at the screws positions. They just can't be mixed up, every screw has its right place.
Bewertung 1
Antwort hinzufügen
kal1982 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 10,615
