Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
74 Fragen Alle anzeigen
Is deleted BootCamp partition recovery become possible macOS Sierra?
I have accidentally deleted bootcamp partition on my Mac computer using disk utility because windows 8 has been damaged or corrupted while I try to resetting it. Note that I wasn't using bootcamp assistant to install windows 8. I managed to make my drive into a single partition but when I press alt/option on boot, I still can see the windows boot option and the data stored in it. How to repair my Mac hard drive so the windows boot option disappear?
Please tell me any solution on how to restore the BootCamp partition data back to my Mac hard drive and regain access to it?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You can take the help of a Mac data recovery software that provides deleted or lost BootCamp partition recovery features. Also, avoid using the Mac machine to make sure that no other files gets over-written on that Mac hard drive.
War diese Antwort hilfreich?
Bewertung 2
Sorry to say its not recoverable ;-{
When you deleted FAT32/exFAT partition and make it part of your GUID partition that did you in. A BootCamp install is a bit different than a raw Windows install which is what you did here. A BootCamp install creates a special folder to hold Windows environment in a VM space. A raw install is when you treat the Mac system as if it where a Dell/HP laptop but you made an isolated partition to run Windows vs MacOS.
Bewertung 1
Antwort hinzufügen
James Rough wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 9
Insgesamt: 839
