Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Vertical lines on screen
I was trying to set some adhesive on the screen to keep it in place (as the pentalobe screw sockets snapped off), and I followed the guide which said to heat up the phone with a hair dryer until it was too hot to touch. I then turned on the phone and got a temperature warning. After that, the screen went all pixellated, and had vertical lines going down across it with a bluish tint to all colour on the display. I tried a good known screen, and that was fine. Is there any way to fix this, or do I have to replace the screen?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like you may have cooked the display or somehow damaged the ribbon cable, maybe with too much heat. Would suggest the only option is to replace the screen. I am sure you have tried re-seating the screen cables?
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Albert Einstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 52
