Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
No sign of turning ON. (not sure if it turns on or not)
I’ve been asked to repair an iphone 6 w/ no idea on what’s wrong with it. But here are the facts to far:
  • The battery’s fine (sufficient voltage when tested with a multimeter)
  • The device draws a little less than 1amp when connected to a charger (but no charging indicator in the LCD even after 1 hour of charging).
  • The device is recognized by my PC when tethered via USB (I am not sure if this indicate the device is running)
  • The LCD never lit up at any time during those above procedures.
So What I’m trying to find out is, if the LCD is the culprit (since the phone is detected by my PC, and the phone drawing about 0.88 amps when connected to a USB tester which is about the same current draw when charging a non fast charging phone. (normally 0 amp when the motherboard is faulty)
I hope somebody could shed some light here.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Could be a no backlight or no image issue on this phone.
To check for no backlight issue connect a replacement screen. Then plug battery back in and attempt to power it on.
Then shine a flashlight on the screen. Might need to angle the flashlight to see a dim apple logo on the screen.
If you do see a dim apple logo it means the backlight circuit needs diagnosing and repair which is board level repairs / microsoldering work.
Might have been damaged from previous repair so also good to check components near screen connectors and the connector itself for any physical damage.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Will definitely check that by the end of this day.
But do you think that if the PC does recognize the phone then the phone must be running?
von
Yes that means that the phone can turn on and boot up normally.
von
Antwort hinzufügen
tri5kmark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 34
