Zum Hauptinhalt wechseln
Modellnummer A1707. Veröffentlicht im Juni 2017, erschien dieses MacBook Pro mit Kaby Lake Prozessoren mit bis zu 2,9 GHz quad-core Intel Core i7 Prozessoren, mit Turbo Boost bis zu 3,9 GHz.
327 Fragen Alle anzeigen
MacBook won't power on after display replecement
Hi,
I changed the display assembly from the macbook. After the replacement no image. The trackpad clicks when I power on the macbook but touch bar en green light shift does not work, no fans spinning. I can see an extern mouse is “working” when connected (red light from the mouse). 1 time the fans were running and another time I heard the charging bling (bling bling bling bling bling, … until i pressed power button). The GPU is getting hot (not extremely) when macbook is “powered on”
No visual damage to the logic board. What can be the problem and how do i fix this?
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Can you tell us why you replaced the display assembly. What lead up to it and where did you get the screen?
von
MacBook had broken screen. Still working but lcd was damaged. From my chinees supplieer .
von
Check for shortage on the LCD cable or ribbon damage. Use the old LCD or a new one to plug into mainboard and see if you get image displayed. Did the OS boot up prior to the screen change? Try external monitor. Possibility of shortage somewhere on mainboard due to new faulty LCD cable or PC boards.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Disconnect the battery again and pull the ribbon cable going to the T-CON board from the logic board. Plug in an external display and see if the system starts up that way.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Just tested with the external display. Still the same problem...
von
I don't get it! The external should light up. I think the new display was defective and zapped your system.
While you don't want to here it I think its time to visit Apple see what they say.
von
Antwort hinzufügen
Mattis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 116
