Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
820-3476 Water Damage Green to Orange Light | NO BOOT | NO FAN |
I have no boot, no fan, I do have lights but PP3V42_G3H all capacitors on that line ground on both sides. I’ve cleaned the whole board, and every capacitor I cleaned specifically on that line to no avail.
SMC works because I can reset it and the lights on the charger will change and all that, but it won’t boot.
There is no corrosion on anything related to the line, and the only thing that had to be removed was C5250 because it was the only Capacitor on the whole board which was corroded enough to cause concern.
I don't know where to look at all! I need someone who has handled this problem before, I’m always up for a challenge and don’t mind putting any amount of effort into this one since it’s a first for me. Good learning experience.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To get a spontaneous reboot: Disconnect the battery and the mag-safe. Press and hold the power button for 15 seconds. Reconnect the battery and mag-safe. If the logic board is good you should get a reboot spontaneously.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
@mayer Tried that, it does not work. Will not boot. Won't even try, I get absolutely nothing. But my SMC still works which is SUPER surprising, and confusing.
von
I'm clueless, maybe @danj has an idea.
von
Time to pull out the schematics and board views, peering into a good microscope with your DVM in hand to do a deeper inspection ;-}
Debugging logic boards is an art onto its self! Liquid damaged or not. I would jump over to Louis Rossmann's YouTube channel and watch his process of isolating out the circuits and finding the failure.
von
Thanks guys!
von
Antwort hinzufügen
Noah Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 352
