Zum Hauptinhalt wechseln
ASUS ZenPad S 8.0 was released in August 2015. Model number: P01M with Intel Atom Processor Z3530
Why the tablet would only charge when it is on?
My Asus Zenpad  would only be charged when it is on. I have used the factory cable and charger (adapter) and also used others. the result is the same. It would charge when the tablet is on; it would not charge if the tablet is off.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi this could possibly be a battery or charging port issue. I would check the port and see if there are any bent pins on the inside of the port.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
phil philirvine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 105
